My Samsung ecobubble washer keeps stopping during its first cycle with 35 minutes on the display, or occasionally 5E.
Last night whilst it was stuck at 35 min I drained some water out of the drum using the tube on the filter housing, as the water level dropped the machine started spinning and the drain pump started up with the machine going on to complete all the rest of the cycle and finish the wash without issue.
My initial thoughts were this was a drain pump problem however once the level had dropped the drain pump worked just fine, lots of people on the internet speak of board issues with these washers but this doesn't seem to match their symptoms.
Just thought I would post here just in case anyone had had a previous experience of this fault, or find out if it's time for it to go in the scrap pile.
Any help gratefully accepted.
Paul
Paul
