- Joined
- 1 Sep 2020
- Messages
- 5
- Reaction score
- 0
- Country
I'm looking for some help / advice on a Samsung American style fridge freezer RS21DCSV which we purchased back in 2004. As it's quite old I'm not sure if it's worth getting it repaired a I suspect a lot has changed during the last 16 years, as far as design and reliability is concerned.
The fridge works fine, but the problem is the freezer. The temperature display above the water dispenser shows -18c but the temperature in the freezer is only about -12c. It makes no difference what I set the temperature to, on the control panel as the inside temperature does not go down much below -12c but the display seems to think it's at the requested temperature. The displayed temperature and the actual temperature don't match so I'm not sure if the problem relates to the control board or the temperature sensor or something totally different
Has anyone else had similar problems? if so, what did you do to fix this problem?
