Hi friends,
I have a samsung oven which is rated at max 3400w which i assume works out to 3.4kw.
My question is which cable and fuse size is suggested by the experts here,
Ie I think 4mm and 20/25 fuse/mcb will be enought BUT is it best to install 6mm and 30 fuse/mcb (or will this be too much?)
Another question is Why are terminal points used (behind oven), ie why cant we wire direct from oven to CCU (above worktop, ie what is the need for terminal box)
Thanks to all and appreciate any advice espcially on question 1
