Sand paper for new B&D sander
12 Jul 2011
Yorkshire
Hi there, I'm new to this forum - just started DIYing and I've got a question.
I've just bought a Black & Decker 240W Compact 1/3 Sheet Sander Ka320Eka which came with 5 sheets of sand paper which stuck to the velcrow on the back.
Now we've used them all, we're not sure where we can get any new paper that will stick - we only managed to find ones that wrapped round the ends (and they kept snapping)
Please can you advise.
You need to buy abrasive sheets that actually have the velcro already attached - no other kinds will work. The papers you refer to are simply clamped to the sole plate of the sander - not applicable in your case!
The easiest bet is a B&D outlet, but Wickes do a range of velcro abrasives that will do. They may need cutting to size but I'm sure the staff will advise you.
John :)
it has clamps as well burnerman :)
buy a roll off "quality" sandpaper for about £15 for 25m and get around 60 sheets from it
The velcro type on sander wears very quickly, so you either need to replace base pad or have alternative fixing method. My makita needs new pad £45!!
