sandblasting
3 May 2012
Kent
hi i m new to this forum i would like to find a sand blaster i have a comprsser with a 2.5 hp motor go s up to 120 psi , i will be using it to remover paint and some light rust if anybody can stear me in the right direction as to what i would need many thanks
zacb :D :D
thank you gents that has given me something to work with thank s
zac :D :D :D
Automotive suppliers Sealey do a few.
They consume air per cfm. (cubic feet per minute)
So check out first what your compressor will supply.
I run mine at 140 psi its ok for rust but not that good on paint, I also have a large tank. plastering sand is the best, builders sand is to fine, sharp sand blocks the gun. use a mask as sand is not good for your health, the shot blasting beads are a waste of money.
