Hi guys,
I've had my entire living room skimmed (over plasterboard) and have applied a single coat of Dulux Supermatt watered down by about 25% to all the walls and ceiling.
Once I've filled and sanded a few cracks that have appeared, do I need to sand the walls and ceiling before I apply the second coat of paint? and if so, what grade sandpaper should I use, and do I need to wipe the whole area down afterwards with a wet cloth before I apply the next coat to remove any dust that the sanding down has left on the walls?
And should I apply a second coat of supermatt before I start applying my 2 finish coats of endurance matt?
Thanks in advance
Thanks in advance
