Hi all.
I am currently redecorating a bedroom in my house.
We had a plasterer come around to have a look at the walls and he said that they didn't need skimming.
I have stripped the wall paper off the walls and used polyfill on any cracks and holes, and I am now sanding the walls.
The plaster has a layer of paint on it and the sanding works fine on these areas and also on the areas where I have used the polyfill. The problem is that in some areas the paint has come off with the wall paper, leaving the plaster exposed.
When I try to sand these areas of exposed plaster they just won't go smooth. Should I try and seal them with some polyfill before sanding? Or is there some other method?
Thanks for any advice.
