After about a year in progess, I am just about ready to sand the floor. Although I've read everything, including WoodYouLike's handy guide, obviously MY floor doesn't conform to anything else exactly , and I need to know if the same recommendation still apply. The details:
* Room is about about 5m by 5m.
* Blocks are reclaimed pine (I think. Probably. Most likely. Not hardwood, anyway.) They are 21cm long x 7cm wide x 4.5cm high. I spent many afternoons scraping the bitumen off the bottoms, so they were 95% clean on laying. They are laid in a herringbone pattern (right angles to wall, not on the diagonal). Around this is a border of larger blocks (the originals from the room that were still usable), leaving 1 cm gap to wall, which will be covered by skirting, yet to be installed.
* Used Rewmar polymer -- expensive, but reasonably easy to use, and no odour. Seems pretty well stuck down.
* Most of the herringbone sits pretty tight, with gaps of 0.5mm to 1mm here and there, and maybe up to 2mm in one or two places where the *&%$£! blocks were slightly off-size, I think.
*Biggest issue is the different heights of the blocks in some places. Tried to ditch the most worn ones, but some slipped through. So there are a lot of differences of around 1mm between adjacent blocks, and up to 2mm in one or two places. Would I be better off digging out the two or three worst blocks and replacing them, or can sanding cope with that big a rise?
*Belt sander or drum sander? Have had one recommendation that it's too big a job for a belt sander, but am aware of the marking problem with the drum.
*Are there different qualities of hired sander? The range of weekly rates at the local hire shops is huge! Anything to ask before taking one?
*Grit recommendation, given these details? Still 40 - 80 -120?
And anything else I need to know?
