My old property has gutters formed in sandstone and lined with lead.
Problem is, they're just not deep enough and next to no fall towards outlet.
I'm going to remove the lead and build up the edge of the sandstone to give more depth and then replace the lead with new.
I'm looking for any suggestions as to what I should use to build it up.
I thought the best solution may be to shutter the front and insert some plastic 150mm pipe within the gutter, then fill with concrete (then remove later).
Problem is the bay is semi-circular, so could be a problem with the pipe theory.
Any better ideas?
Any better ideas?
