Hi my macerator is making stranges noises (i've uploaded a recording to http://www.sturobbie.co.uk/sani.mp3 ).
Today I managed to access the macerator and found a pile of hair around one of the valves, which I thought was the problem, I removed all the hair and almost all of the water and then reconnected it all up. It seemed to work fine for about 4 flushes of the toilet and then the noise returned. It then stops working for about 10 mins which I assume us to protect it from overheating. I've checked that the blade chamber was clear (it was) and that none of the holes were bunged up (they were al clear). I'm probably going to have to disconnect the macerator and take it apart to investigate further, but I was wondering if anyone might recognise the fault just by the noise its making to save me a lot of faffing around!
Also, there ae two drainage pipes connected to the macerator with what look like overlapping clips with lots of little teeth, how do I disconnnect those?
Any Help/Advice would be greatly appreciated.
Cheers
Stu
Cheers
Stu
