Got a question about these heaters.
With the following configuration
View media item 24670
When expansion occurs.
A. does water expand into the expansion vessel
or
b, does water pass the pressure relief valve and then go to the drain.
If its A, surely the expansion vessel can only hold so much water so what happens when its full
or if its B, why does it say in the trouble shooting guides if water passes through the tundish or PRV intermittenly then there is a problem.
Thanks in advance
or
Thanks in advance
