I had a Santon Premier Plus installed 18 months ago to replace my ageing Gledhill Accolade. Everything was fine and dandy with lots of lovely high pressure hot water until I had a new bathroom fitted. Since then the hot water seems to run out much faster. There is another occasional symptom: sometimes, even on the first shower of the day, I have to put the mixer tap on a much hotter setting than normal to get my desired water temperature. I presume this is caused by the temperature or pressure of the hot water being lower than normal.
I'm a bit mystified by all this, and unsure whether it could be caused by the bathroom works, or simply a coincidence. It could be that the new shower head simply uses more water than the old one, although it doesn't seem to. And that wouldn't explain the occasional mixer tap effect.
I had a similar problem with the Gledhill earlier in its life and was advised to recreate the air buffer by doing the following, which worked. Could this help on the Santon too?
1 Turn off the power to the elements
2 Turn off the water at the stopcock
3 Open the lowest hot tap and when the water stops leave it open
4 Turn the pressure release valve on the side of the cylinder - about 1/2 way up on the left - and water will flow out through the drain
5 Keep valve open until the alarming gurgling noises inside the cylinder calm down and water stops flowing - can take a few minutes
6 Close the hot tap
7 Turn on the water at the stopcock and wait for the gurgling to stop
8 Open hot tap slowly - the pressure is surprising - until air out of pipes
9 Turn the power to the elements back on
6 Close the hot tap
