hey every one,
I have a SANTON unvented system model: TP150E.
I need to drain all the water as I need to change the lower heater element. However, I am only draining it using the drain valve at the bottom of the boiler. I can't get pressure to take out the rest of the water inside.
I think there's limescale blocking the drainer, not sure now.
I thought by letting the taps run, it will drain the water but there's gallons loads more but nothing from the taps.
Does this mean that the top part has been emptied and I need to drain the rest using the drainer?
If so, how and when does the water at the bottom ever be used via the taps?
