Hello,
Just wanted to ask for suggestion and ideas about what to do with our water heater.
We've just moved to a new flat with 4-5 years old water heater in it. And less than a year ago its elements had changed and serviced. So we weren't expecting any problems for some time. However there is no hot water coming out anymore but when we press the boost button than we get the hot water. The pressure of cold water is fine and hot water after boos everyting else is good other than no hot water. It's a Santon Premier plus 150 L.
Are there any solutions to fix it easily or do I need to call a plumber or electrician whichever is better for this problem?
Thank you
Thank you
