sash lock on wood door
10 Jan 2007
looking for ideas on how i can open a door on a property were a letting company has been left with no keys , a sash 3 lever lock is fitted to back door and has no keys to open it
any help would appreaited
First step is to contact the agent
second step is to contact the previous tenant
third step is to contact the owner
are you inside the house?
Have you got an angle grinder?
the agent has no keys
the land lord has no keys
previous tenant has change lock, hence nobody has no keys
there asking me to change lock , but first i need to gain access to property
to change lock
you only mentioned the back door
if you can't get in, then the owner needs to employ a locksmith.
Be aware that no-one on this website can tell a poster who is a homeowner from a poster who is a trainee burglar.
im not a trainee burgluar, been putting post on here for over 4 years
just looking for advices or tips on opening door
tyoy
If its a 3 lever lock, then it's a very simple opening for a locksmith, who will have you in within minutes of arriving. Once in the lock needs changing for a 5 lever BS rated sashlock that meets insurance guidelines for the property.
If you are doing the work, ensure you obtain written authority from the letting agent authorising you to gain access to the property - you will need this when the local PC comes to have a friendly chat with you.
In your shoes, I'd sub out the door opening to a local locksmith, then change the lock yourself. You'll only cause damage to the door/frame, requiring materials and time to rectify - cheaper to sub out the opening.
