I'm currently adding network/media cabling to our property. It's been a while since I last did it and satellite/tv distribution has moved on but there seems to be a few different ways to do it.
I have 6 rooms with a TV point, probably 3 will need satellite, so 2 feeds for the living room and then at least one per other room - flexibility to add recorders here would be useful.
No plans for Sky Q (only FTA/Freesat at the moment) but it seems sensible to have a solution that is compatible or can be expanded to support later.
So, probably a multi switch in the loft but what do I need at the dish (standard Sky minidish), which multiswitch variant etc?
Also the house is currently wired in the living room for a "return" cable for the old sky boxes, is this still relevant anymore and should I look to retain when replacing the cable?
Thanks for any help
Thanks for any help
