Hello, I'm painting MDF cupboard doors which were previously plastic wrapped, now removed, so starting from an unfinished surface.
Primed, left 24 hours, lightly sanded, then Dulux professional white undercoat, left 24 hours and lightly sanded, then top coat of Dulux colour-mix satinwood.
The top coat brushes on evenly, then within seconds streaks appear. Best way I can describe it is as if the undercoat has rejected the satinwood along the lines of the brush strokes, like the surface was oily. It looks terrible.
I stopped after painting two doors, left them overnight, and just tried a second coat. It's better this time, but there are still some noticeable white streaks, and I'm concerned even more coats are still not going to completely cover them.
Primer was the remains of a year old Screwfix own brand tin, both Dulux paints bought new a few days ago. All paint thoroughly stirred before use. Painting, and storage between coats, in a dry garage.
Incidentally I painted a patch of the satinwood on a piece of unprimed scrap MDF. It's obviously gone a bit mottled as the surface absorbs moisture, but none of the oily streaking. Have I used the wrong undercoat? Technique at fault? I've painted pretty much every interior surface of a flat and three houses over the last 20 years, including a set of cupboard doors, and never seen anything like this!
Ian
Ian
