Saunier Duval F24
2 Nov 2010
Edinburgh
I have a Saunier Duval F24 combi with an analogue timer. Apparently there is an electronic programmer kit available SD part A20087. Are these simple to exchange, and can anyone recommend a supplier for the kit.
It would be cheaper, better and give more facilities to fit a programmable thermostat.
Tony
Thanks for your response - that hadn't occurred to me. The main objective is to provide different settings for on/off on different days of the week. Can a programmable thermostat provide that?
Not only that but it can set different temperatures at different times of day.
Tony
trust me you dont want that built in clock! get an external jobbie or as agile has said a prog/stat.
So is it a case of unplugging the wiring for the existing timer and replace with the new one - is the wiring going to be the same? Or, is there any way I can make sure the wiring will be the same.
