Hi all
We have a Saunier Duval Thelia 623 that has just started giving us trouble. In short, we have no hot water, although the central heating works fine.
When the hot water tap is open, I can hear the boiler becoming active. The fan goes off, but it won't fire. The pilot is lit, but it just won't fire. It will fire just fine for the central heating however. If the boiler is fired up for the heating, and you turn on the tap, it will turn itself off until the tap is closed
I can see that the pin from the valve-diaphragm is being pushed. I replaced the diaphragm earlier this year as it broke, so this is not the cause. The microswitch also appears to work fine. Going through the fault finding chart in the manual leads me to a circuit board replacement, but this is an expensive part, and I rather rule out other possibilities.
In the meantime, I have disconnected the wires from plug "3" in the micro switch assembly. This means the boiler cannot detect when the tap is open. With this measure, as long as the central heating is on and the boiler fired up, we can also get hot water. Not ideal, but works as a temporary measure.
Any ideas as to what may be causing the problem?
Cheers
Cheers
