Saunier Duval - Thelia 623 (pump replacement)
26 Oct 2007
Essex
The problem is I have water seeping from the pump on my Thelia 623 boiler in two places. Firstly, from the front where there is a brass serrated cap (to front of pump just behind boiler casing when opened) and the second leak to a pipe on the left which connects the pump to a jubilee clip and rubber hose and onto what is either the copper flow or return pipe. I am presuming the pump requires replacement however, is this a fairly straightforward job ie; just unbolting and bolting new unit back in place ? OR can it be taken apart and repaired ?
The brass cap is an automatic air vent. They often leak from the little black cap. They the are the top part of a standard Caleffi 1/2 inch vent and should be less than £5.00. Just drop the boiler pressure and replace it (no need to remove the pump).
The hose connection can sometimes just be nipped up a bit. However the plastics on these boilers are notorious for becoming brittle. You may find the plastic connection just shears off! On some of these pumps the parts listing just shows the plastic moulding on the side of the pump is available as a seperate part. Not sure whether this is still available though. You'll also need the hose kit (2 in a packet).
If you need a complete pump they were about £150 last time I checked. The cheaper ones from Antares are of dubious quality.
Treat the boiler like a UXB otherwise it can start leaking from the reversing valve and a host of other places :(
This is the only model we refuse to work on if its a water issue because of the propensity to leak from so many different places.
Most people would advise the boiler should be replaced with another make.
Tony
Hello - digging up an old thread as I have the same problem (leaky little black cap on top of the pump air vent). Can anyone tell me where I would go to buy one of these, and indeed what I would ask for?
Yes, I know it is an outdated boiler, and it does ooze a bit elsewhere, but at the moment I can't afford a new one, though do plan to replace in the next year.
Graham
