Saunier Duval Thema Classic F24E losing pressure daily
Status
Not open for further replies.
5 Feb 2009
London
Morning
Since the onset of the cold weather last weekend, my above combi boiler has been losing pressure when off (overnight and when at work in the day) such that I'm having to use the filling loop just to get it going again. Once running it maintains pressure and is fine, but losing pressure once it's cooled down again.
I've bled all the radiators and filled boiler back up as necessary, but same thing happened overnight last night.
Noticed this morning when filling from cold that water was coming out of the pressure release valve pipe that goes outside, even though per the LCD pressure gauge the boiler was between 1 and 1.5 bar at that time.
Is this simply the PRV that is shot (and thus do i need one of these: http://www.uk-plumbing.com/saunier-duval-f24e-safety-valve-p-42875.html, or could it be something more serious?
Thanks in advance for your help.
Thanks Steve, will fit a new PRV and let the forum know if this fixes it.
Any reason why this should have happened with the onset of the cold weather or just coincidental?
and the expansion vessel hose is either kinked or blocked. (poss both)
Hello Manfield and others. We have a similar situation...described below:
We have a 7 year old Saunier Duval Thema f23 and have the British Gas Homecare 200.
5 British Gas “engineers” have come over 5 times in the past week and yet, cannot explain why the boiler works fine and maintains pressure when it is switched on and why the pressure drops to 0 when it is switched off. They have suggested many things and now, after ripping out some floorboards, they are threatening to rip out our new tiles and walls in search of a mythical leak!!! Details below:
On 5th of February 2009 (temperature was -1 degrees centigrade), we had an engineer from British Gas come to service the boiler. He serviced the boiler and fitted a Hydroflow unit for £150 as well.
The next morning the boiler started making whirring noises and then we smelt burning and then the noise got louder and the boiler seized up and cut out. The pressure gauge displayed 0. We phoned up British Gas and they kindly told us to get National Grid.
The National Grid engineer was fuming and told us that this was standard practice for British Gas and told us that there was nothing wrong with the gas system and left – he also told us that he had to personally speak to and convince British Gas when they refused to answer the call of a 89 year old lady who was literally freezing to death on the grounds that National Grid had to go first and check the gas!
The British Gas engineer then came with a plastic tupper box with a few screwdrivers (no toolbox required for these engineers) and proceeded to insert pieces of tissue into the boiler. He then told us that the previous engineer forgot to tighten a few screws and that might have been the cause of the problem. He then used his fingers to manually move the boiler sensor switch (this is a spring loaded part) and then announced that this was the problem and said that a new part needed to be ordered. As we still had no heating or water, he topped up the pressure and told us that we might get some lukewarm water when the heater was running but could not explain the burning smell or anything else. We asked him if the radiators needed to be aired and he said that was not necessary. He seemed to be in a hurry to leave.
He left and an hour later, the pressure was in the red zone (3 bar) on the dial. We aired the radiators ourselves and that was that.
The next morning, the boiler came on at 6am and after about 5 minutes, started making whirring noises. The noise got louder and then the boiler exploded with a loud BANG and a massive burst of steam.
We phoned British Gas again and went through the story and the operator asked us “what do you want me to do?” Anyway, such encouraging customer service and after a long pleading conversation, an engineer came on Tuesday and changed the switch and any other parts that might have been sitting around in his van. He left and said all was well. An hour later, the boiler came on with the timer and we heard it whirring and it cut out. The pressure displayed 0.
British Gas then sent the same engineer on Friday, this time accompanied by a “senior” engineer (does this mean that we get junior engineers all other times?) who joined the junior engineer in “fixing” the boiler. Additionally, the senior engineer also criticised us for having floor tiles in parts of our house as he said that this makes their lives harder! "This is what you get when you put them fancy tiles - we might have to rip 'em out"
This time, they replaced the water valve, connection pipes and they also "checked" the expansion vessel, the out flow pipe and told us all was well.
An hour after they left, we switched off the boiler, went out and came back and the pressure was 0.
They came back two days later, and then moved a few more things around and then announced at the end that there might be a leak in the piping system.
The engineer came back the next day and filled up the boiler pressure and watched it go down to 0 in an instant. He did this 5-6 times. This means that we are “leaking” 2-3 litres of water at a time! He then ripped our floorboards and couldn’t find a drop.
They still could not explain why the boiler works fine and maintains pressure when it is switched on! The pressure only drops to 0 when it is switched off.
Now they are threatening to dig up the tiles and cut into the walls of our 1-year-old extension where the heating pipes are sunk.
Our builders have come in and kindly checked everyting have assured us that there CANNOT be a leak as there would be evidence of water leak on the tiles and the wall. They have also used a Moisture Meter and have told us that there is no sign of leaking water. They tell us that walls and floor tiles would show evidence of water leak given the amount of times that the British Gas guys have topped up the system. They also tell us that the Boiler heat exchange might spoil with the amount of topping up with fresh water.
The British Gas “engineers” have also told us that they are not responsible for the damage they cause as a result of looking for this mythical leak. They also don’t feel that the pressure gauge might be faulty! They also don’t want to change the expansion vessel!!!
They also told us that they will only search for this leak for a value of £1000 after which we will have to foot the cost. They also don't answer us when we ask of the possibility of not finding a leak!
5 engineers (one is senior at that hmm…) have visited 5 times with a 6th visit in a few days and yet, they cannot explain why the boiler works fine and maintains pressure when it is switched on and why the pressure drops to 0 when it is switched off.
The tactic from British Gas seem to be to firstly sell you the Hydroflow, then order some cheap replacement parts and then search for mythical leaks for the value of £1000!!! What next? Poke a hole in your piping system when no one is looking? Suggets that rats have chewed through the copper? Elves? Imps?
More to follow unless someone can provide some sanity please!!! This is our 12th day with no heating!
Wow - sorry to hear that Frozen, i hope you get it sorted soon. Does anyone know if Homeserve cover Saunier Duval boilers (mine's from 2004)?
Anyway i changed the PRV at the weekend. Tried to top up the expansion vessel, but it's in such an awkward position at the back that i couldn't get a pump onto the valve. Fingers crossed, however, it seems to be holding it pressure now.
Thanks to all on the forum for their assistance.
FBBG- Why doesn't someone isolate the boiler for a few hours just to confirm whether the leak is on the boiler or on the system? That would be one of the first things I would try. :rolleyes:
After the 1st visit I'd have been lookin @ is the vessel holding air charge ok? Is the pipe kinked/blocked Is the prv ok? Ie leakin out the overflow? Does the pressure rise excessiveley when the heatings on? Then isolate the boiler for a few hours at least possibly overnight if it holds pressure = system leak if still drops the boilers leakin internally Which means no property damage :) ... Not to familiar with the boiler if its condensing main heat exchange could be passing through the condense pipe simple to check if the boilers off and has been for a while undo the condense pipe if there's water dribbling out u need a main heat exchange If its not condensing the only other place to lose pressure is through the prv if the boilers isolated!?
Status
