Take it from someone who regularly rips down sheet material on site, sometimes into narrow strips, a track saw is completely the wrong tool to use for the job of ripping strips narrower than about 150 to 200mm. This is because the rail needs to sit fully on the piece you are ripping to make an accurate cut without slipping - something that even we trades types can sometimes find a challenge. It is far easier, faster, more accurate, more consistently repeatable not to mention cheaper to use a standard rip saw (I.e a portable circular saw) with a side fence to do the job. At work I generally have the choice between a Festool plunge saw and rails (or a cordless Makita plunge saw and rails) and my little 165mm 18 volt rip saw for such a task - and for the reasons stated I invariably choose the cheaper cordless saw (fitted with an appropriate blade, of course - 30 to 48 tooth in 165mm as it happens), despite being enamoured of my rail saws. Horses for courses! The other thing you can do with a conventional rip saw that is awkward, error prone and time consuming is to re-rip narrow MDF strip such as architraves and skirting - a task that a rail saw is completely unsuited to.
BTW, keep the rubber strips on the underside of the rail clean and they are sticky enough on plywood and MDF that you'll rarely, if ever, need to use those clamps to hold the rail in place. You rarely see trade users with a pair of those in use for their I tended purpose
