I'd like to add some extra storage space to my garage just beneath the ceiling. I thought to fix some scaffold tubes between the walls to store long bits of timber on, however most of the fittings for attaching tube to the wall seem to be ties, rather than load bearing brackets.
Can anyone recommend a fitting that will do what I want? I'd estimate the total load will be not more than about 300 Kg (excluding the tube), spread between four fixings (two tubes). Maybe add another tube if I get carried away.
What I'm looking for I guess is the load-bearing equivalent of this:
http://www.scaffoldingsupplies.co.uk/products/details/154.html
If I can't find what I want off the shelf, I plan to get a local engineering firm to fillet-weld me some 40mm OD tube (4mm thickness or more) onto 8mm plate 200x200 with M12 holes at 150mm centres. Then just locate the scaffold tubes onto the 44mm tube and bolt it all into place. Maybe I'll go the other way and create a collar for the 48.3mm tube instead, just depends on what size tube they happen to have.
The other question, is if the bending of the tube under load is going to disturb the walls, and if I need to leave some allowance for that (i.e. let the tube slide away from the fitting a bit). It's not a double-garage, but it is on the large side, certainly a bit wider than the normal width of a scaffold bay.
thanks for any advice,
S.
S.
