Scanner for negatives
3 Jun 2007
N East
Which is the best reasonably priced scanner for 6 x 6 negatives please
Are these two replies supposed to be some sort of contribution, if so I fail to see it !!
I was thinking Kiev 88 or similar 6cmx6cm neg
Sorry you have not had any responses from anyone who can actually help.
Have you got any DIY problems?
Q asked here - 2004
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=007x3O
Points to here :-
http://www.betterscanning.com/
Medium format film 220 or 120 is 60mm wide, no sprocket holes, former does around twice the images of the latter, has opaque backing on leader and trailer only, 120 film has full length backing.
Camera design fixes the final negative image size.
Example... a discontinued model...
Fujifilm Pro GX680
Fuji on the GX680 said:
type of film:- Roll film 120 / 220, instant film FP 100 C (or corresponding type) with instant cartridge
photo format 6x8 [cm]
6x4.5, 6x6, 6x7 [cm] using format masks (available as an option)
Thinking about it, I used a Balda folding camera with Baldanar lens using 120 film, way back in the 60's. The camera produced two and a quarter inch square pix... So that 57.2 mm square image would very likely have been your 6x6cm format !! Good camera.
-0-
My 3 or 4 yr old Epson Perfection 1260 gives reasonable results, but I would imagine it would depend on what application you require.
Scanner I have here is a Scanmaker i900 from microtek.
Has a negative carrier for most common sizes and works very well.
Does negs and transparencies.
Only problem was the price................
If you are into photo imaging this has to be one of the best...
