Hello, I hope that this thread is the correct one, as it is rather difficult to classify my problem.
I have a Umax Astra 6450 scanner. Although it is quite old, I suppose, it is not frequently used. Over the last month or so, although the scanner itself worked with no trouble, the line-switch between the mains socket and the power-jack for the scanner would not switch off — to get the scanner to shut down, I had to pull out the power-jack.
Then, for a short period, the switch started to work again. Then it failed again. So, I bought a new switch, and today I installed it. However, now, the switch does not start the scanner's ON light, at all (whereas the old switch did not switch the scanner off).
I have put a new fuse in the plug that goes into the mains. I have tested the relevant socket by plugging a fan into it, and the fan works. I have plugged the scanner mains plug into another socket that works with other appliances, and it still does not switch on. With a neon screwdriver, I have touched every terminal in the new switch with its cover off. The neon does not light up.
Of course, it may be that the scanner is finished, but if so, why does the neon screwdriver not light up?
This is a total bafflement to me. Can anyone offer any useful advice? The photo shows the type of power-jack that plugs into the back of the scanner (if that is of any use, which I doubt). The diameter of the jack-plug is about 6mm.
In hopes of some help,
L.L.
L.L.
