I have a 15 year old Scantronic alarm.
I was cleaning and knocked the control box, resulting in the alarm going off.
It wouldn't reset and I had to wait 10 minutes for the external siren to stop.
I removed the control box lid, expecting the alarm to set off again. It didn't. I noticed the tamper switch inside the control box is very loose. You can rock it sideways quite a bit. I suspect this has failed, somehow.
The separate keypad just has the red tamper led lit.
A few questions:
1. Should I replace the 7448 with a newer model, using the same wiring and PIRs etc?
2. How can I stop the external siren while I work on the control box, either removing the board to investigate and repair the tamper switch, or replace it with something newer?
3. The separate keypad accepts the user code and beeps once after the 4th digit, but nothing sets.
4. I tried entering a new user code 1234, in case it had lost NVMemory. It went to full alarm, stopped by entering the correct user code.
A few questions:
