The alarm sounded and gave a tamper fault,reset and internal sounder stopped,but the external one will not shut off.Have reset numerous times,powered off removed mains and battery from unit,powered back up reset again still external is going off.After it stopped sounding i linked out 0v and TRN in the panel.It now seems to function ok,12v battery was replaced a few months ago,and is holding over 13v when tested out of the unit.Im thinking a battery fault in the bell box or a short etc due to water ingress,is there a way to check without getting ladders up.
Have tested with the link in and external box does not sound,only the internal panel sounds,is this correct ?.ie does the 0v and RTN need to be wired in for the external bell to trigger ?.
