Scantronic 9448+ Fuses blowing.
31 Aug 2024
This alarm stopped working and the tamper loop light was red. Inside, the F2 aux fuse (1A fast) was blown so I replaced this and put in a new battery. Reconnected mains but F3 Vac fuse (1A slow) blew. Disconnected battery and replaced F3 fuse. Reconnected mains and internal sounder worked, entered code and stopped and all seemed OK. But when I reconnected battery and then mains the F3 fuse blew again. Very grateful for any ideas.
Normally the F3 fuse will only blow if the battery has been in too long and the transformer is overheating when trying to charge the battery ….replace fuse and disconnect the battery ….does it still blow the fuse ….?
Thanks for reply. Yes. I disconnected mains and battery. Replaced fuse. Left battery terminals disconnected. Turned on mains and alarm sounded for 2 seconds and F3 fuse blew. I'm puzzled as to why the F2 fuse was initially blown and the F3 intact. Outside bell box is Kinetic AZ 220+.
Disconnect the + and - wires from detector ( aux supply ) and bellbox + and - ….with battery disconnected , if it blows fuse now it’s probably time for a new alarm panel
Can I just remove the aux supply fuse and disconnect the bell/strobes bell, 12V, 0V and TR. There are 3 detectors plus a separate door detector(EE). I think I will get the installer to come and fix next week. This alarm system has lasted 20+ years so very happy to replace like with like but should I think about anything newer? Many thanks for your help.
