Scantronic 9448 Help please.
Status
Not open for further replies.
13 Feb 2008
London
I have a scantronic 9448 panel and am trying to connect a gardtec nova 2 merit ga series external sounder (screwfix special ) but the bell although new has no wiring instructions and i am told i need to put in a link in order to make it sound and also i have no idea of the connections from panel to bell,could someone please advise.
ring the supplier and ask for the instructions?
Hi m8 tried that with no joy
what - screwfix ?
Even without instructions , there will be a sticker beneath the terminals of the siren , with industry standard info , the terminology changes slightly from manufacturer , but still similar.
scantronic------gardtec
STB-------------STB- (neg to fire the strobe)
BELL------------ BELL SW- ( neg to fire the siren)
12v------------- +12v (perm hold off voltage )
0v-------------- 0v (perm hold off voltage )
TR ------------- TMP RTN (tamper return)
link 0v to tamper feed
if you are unsure , connect to the panel with a short piece of cable first.
if you are unsure , connect to the panel with a short piece of cable first.[/quote]
You my friend are a star many thanks...... :D
It has the same wiring connections so why so anal?
you didnt get the technical bulletin did you ?
like I said before theres a fault on the print and you HAVE to fit an additional wire link
Well tell the man what it is then. Is it a tamper feed from Ov? Don't keep the man waiting trying to prove a point.
hey if he hadnt throw his dummy out the pram at the start then I might have, as it is he`ll have to wait till the box starts "chirpping..." when its wet or cold to find out
Load of piffle. If you can't help - you know where the door is.
Status
