scantronic 9448+ style help
20 Oct 2013
Sheffield
I recently moved into a house and the alarm randomly went off with zone 6 illuminated. When the code was entered the alarm silenced but it didnt clear the system zone 6 still illuminated. Is this a case of having to reset the system or a fault with the zone 6 sensor. P.S previous owner hasnt left the users manual so dont have the engineers code or anything. Any help would be really appreciated. Thanks
What is zone 6 ? It can be a panic alarm on zone 6 check for a small matchbox sized unit with a red push button on it , it may need a key to reset it.
ahhhhh yes i completley forgot about that we dont use it and at the minute its just coiled up but with a 2 year old running around that would explain it. im not sure the previous owner has left a key for it so will have to have a look. Thanks
Was going to say have you got kids ! Lol . you can undo the front and push the magnet back up to reset it,the window may now show green
Code once to shut it up (check LEDs) and a second time to reset the alarm
Set/unset system. Code
Part Set. 2 + ENTER + Code
Omit Zone. Zone No. + OMIT + Code
Keypad PA. 1 + 3 (together)
Bell Test. 4 + ENTER + Code
Walk Test. 5 + ENTER + Code (OMIT to end test)
Change User Code. 6 + current Code, current Code again, new Code
Chime on/off. 7 + ENTER + Code
Read Log. 8 + ENTER + Code, 1 to go back in time, 3 to go forward
Blimey! It took me so long to type out the user guide that there's been a complete conversation!! :eek:
I've used a small Allen key to reset a PAB...
