Scantronic 9448 + style problem
5 Dec 2024
Hi, i have a scantronic 9448 + style , that goes off randomly when the system is not set, whilst this sounds like a common back battery problem its coming up as zone 2 was activated even when the system was not set, tamper not coming up either. any ideas.
Replace the battery if it’s a battery fault?
What is zone 2 programmed as? Tampers and 24 hr zones will activate when system is unset.
How many zones are wired?
Zone 2 is a normal alarm zone with a PİR detector on it.
Check all voltages on this panel inc what is coming out of the battery leads ( battery disconnected ) have replaced a few this year with low voltage issues 7-10v
Should be 13.8
