I have inherited this system - Scantronic 9800. I would like to carry out a service but don't know the engineer's code. Is this code necessary to carry out the routine service, to the standard of the security maintenance companies? I only have the user's manual which gives the walk test procedure. Is there any common faults to look for with this unit?
Does anyone have a standard procedure which the security companies conform to; or can point me in the direction for the same?
I assume that the battery can be changed easily without major hassles; what is the recommended frequency for this change? - I have seen figures ranging from 5 to 10 years, I don't know when the existing battery was changed; (can a failing battery be recognised in any case?) but I want to do this asap.
Does the bell box have a separate battery which requires changing also?
Any assistance gratefully received.
Thanks in anticipation
