Scantronic Home Alarm 602/625
13 Jun 2010
London
I recently took over a property with the above system installed . The previous occupier did not have a manual, had never used the system and did not have any entry code.
How can I re-set ?
Can I simply enter a default code using 1234+Enter to activate and use ?
this system was one of the worst scantronic ever made,
sorry but they were.
if you are thinking about using it i would reccomend getting an engineer manual for it (as well as a user one),
but you might find it a bit difficult to get them, it has been binned by scantronic for years,
i would reccomend changing the whole ssytem, just leave the cabling in place.
you will have problems with that panel, and no spares are available for it
john
How can I re-set ?
If you can supply an email address, I'll send you a pdf copy of the Install/User manual.
It does explain how to default & reprogramme if you are willing to have a go.
