Good morning,
I've setup an i-on160ex with the speak dialer, isd02.
The dialer doesn't seem to be able to see the telephone line - though the connections are made to the master socket (Socket was just installed last week if it makes any difference and is 5c marked by bt).
Tests so far:
on the master socket, plugged in a telephone - that's working.
removed the alarm telephone wire from both ends, twisted one side together and checked continuity, all fine.
Made connections on both master socket and sd02 again, but alarm still says line failure.
swapped wires over just in case - still says line failure.
the SD02 has no phone socket on it any more, so i cant plug in a phone and check if there is a dial tone.
Any ideas?
Also bt socket has 2,3, and 5 i think, while dialer as a/b.
Which wires should go where (not colors but number to letter).
and lastly, is there a way to initiate a test call from the panel? I cant see anything on software to allow test dial which i find unusual!
Tests so far:
Any ideas?
