hi...i need to get a scart lead through a brick wall, but need to keep the hole to a minimum, is there a way to split a scart lead or can i buy one that has a split connector
cheers
mickcoulson
cheers
mickcoulson
See http://www.satcure.co.uk/accs/page4.htm#wallscarthi...i need to get a scart lead through a brick wall,
Yes, brilliant idea... Drop £30+ on one of those boxes for pretty much no benefit at all, all to save 20 minutes stripping and re-pinning a SCART lead.
Or, here's an idea....Why not read somewhere in a forum exactly how to strip and repin a SCART lead. Then you might not have to drill such a large hole (HDMI plug > SCART cable thickness), and you wouldn't spend £30+ on some random bottom-of-the-heap Chinese made SCART to HDMI box.
Now where oh where could one find such useful information....I wonder?
Good. Because you know I'm right. Thanks"I have precisely zero interest in wasting my valuable time entering into a completely irrelevant debate regarding the relative merits of SCART and hdmi cables with you"
None of that is in dispute. But where does it say in the OP that he's trying to use SCART for HD? It doesn't. So, as you put it - End Of.Suffice to say that HDMI leads must be used to connect HD equipment if you want full HD picture quality. The fact that SCART leads cannot be used if you want full HD picture quality is what makes them, as I perfectly correctly stated in my post, yesterday's technology.
Hee hee. It's certainly pronounced "braddle" but it's spelt "bradawl"..Use a braddle or similar sharp pointed tool.
