I have recently fitted a mixer tap to my bathroom sink. the hot is fine, but the cold side makes a screaching noise apart from when it is open to full flow. The tap can't be faulty because I have tried swapping the hot and cold inlets- it only happens on the cold whether it is LEFT side or RIGHT side. when the toilet is flushed or the bathroom tap is on, the noise goes. I have tried reducing the pressure from the mains, but it makes no difference. I have tried putting a regulator valve on the pipe leading to the cold tap- it only slightly reduces the noise. when the taps were seperate before, there was no noise. Any other ideas how to stop this noise coming from the new mixer tap?
