Screaching noise when toilet refills
9 Feb 2009
Kent
Hello,
Any idea why a toilet would develop a high pitched screaching noise as it nears refilling. The toilet fills from underneath, is flushed by a 2 part button on the top (regular / large flush) and is on a mains pressure system. It was installed 18 months ago and didn't make the noise then.
Thank you for all aopinions received.
Mutley56 :D
18 months of wear+ tear :idea: Very high mains pressure :idea: . Highest I ever came across was in Dover :eek:
Thank you for thye reply.
Does that mean that I need to install a new toilet, perhaps one better suited to a mains pressure feed?
If so, any recommendations for the minimum standards / features necessary in the new toilet to prevent the problem recurring?
Thanks for your advice.
Mutley56 :D
Ok thanks, I will look into that.
By the way, how urgent is the replacement job? Will the loo stop working?
Thanks again.
Mutley56 :D
