(and I don't mean the mother in law...)
Needed to bleed a radiator today. Released the air until water (thankfully clear) appeared.
Later this afternoon noticed that all radiators were cold. Turned the downstairs thermostat as I though that the system had reached proper temperature. But right after this I heard two or three screech type noises from the attic space. I immediately turned off the heating.
Bravely I looked in the loft and noticed that there was practically no pressure on the boiler meter (Vokey - not a combi). I have topped it up again and the the radiators appear to be getting hot again.
Was the screaching just the pump complaining? Did I cause the problem by bleeding the radiator? Could I have caused any damage?
I quite often have to fill the bolier and need to get someone to look at this too - its 7 years old - its also the same (and only) radiator that I have to bleed too.
Thanks.
Thanks.
