Screeching pump
7 Dec 2006
London
My pump makes a screeching noise sometimes. I turn the bleed screw on the pump and let some steam and hot water come out. The noise immediately reduces and then stops.
What is causing the noise and how can I get rid of it?
I love peace and quiet, so any help would be very gratefully received.
Thanks, Chris.
The pump is only about 4 or 5 years old. Is there any way to check if it's OK or needs replacing?
I phoned the IPHE technical helpline this afternoon and the man said that air is getting into my (vented) central heating system, probably from the header tank. When the air gets into the pump it makes the screeching noise. Do you think that's right?
One way to test for air ingression is to put a balloon over the open vent pipe and see if suction occurs when pump runs.
This will give you a giggle when you return a few days later to find the balloon has burst and the homeowner has shoved 'a ribbed deluxe' in the same place.
Unused I hasten to add.
David
Not sure. Randy mandy made me try one, as I had 'indegestion'
Dave
