Screed curing time before laying laminate floor.
14 Feb 2011
Hi
I’ve had to break up some of the screed in my living room to replace burst central heating pipes. After I have installed the new screed (sand cement 4:1 at 50mm) how long should I cure the screed for before laying a laminate floor? Any help or other suggestions would be appreciated. Thanks
There are several other screed options to simply using Sand / Cement additives can "assist" in reducing drying times a bit, if the area of screed needing replacement is small some higher costing chemical options are out there, and they will dry very fast,
I have adhered to the principle that sand cement will dry at about 20.mm / month, that is dry well enough to lay laminate on to
Ken.
