I'm laying some block paving (200mm x 100mm x 50mm charcoal blocks) for a path in my garden. I have been following the excellent guide at www.pavingexpert.com but wanted to clarify something.
On the step-by-step guide he advocates spreading, levelling and compacting the laying course sand to the correct level...
But on the page on screeding he advocates screeding the bedding layer so that the blocks will sit a few mm proud to accommodate final compaction with a vibrating plate.
As an amateur I wanted to see what the opinion of people who regular lay block paving on a a bed of sharp sand is?
I was also wondering if you do level the bedding layer so that it is proud do you not compact it once it is level so as to allow the blocks to be compacted once laid? My thinking being that if you compact it and it is proud then will the blocks be able to be compacted level once installed?
Informed opinions welcomed please.
