Hey everyone!
I am building a concrete block shed, or rarher two sharing one wall. Each one a bit smaller than 7x5 meters. I am about to pour foundation, 60cm deep, 30cm thick and take the blocks from there until i get a bit over the ground level.
Next i will want to lay a concrete slab within those walls. Are you able to advise on what layer thickness of MOT, sand and then of concrete would you use for this? Also shed will be insulated on the inside, so that i can use it as a workshop over the winter. Is it worth putting in floor insulation? I don't want it to be as warm as house, and will just have a small electric heater, so unsure if it's wort doing. What would you advise?
