- Joined
- 5 Nov 2022
- Messages
- 167
- Reaction score
- 11
- Country
Hiya, thank you for reading this
I am building an entertainment wall. I'm planning to build a frame from 2x4s and secure this to the exterior wall. The exterior wall is a cavity wall - red brick outside skin, Thermalite blocks inside skin. I obviously intend to secure the stud wall to the ceiling and floor but I'd like to also put some fasteners into the wall as it's going to hold a few TVs on wall mounts, so there'll be some force exerted - pulling the stud wall away from the masonry wall. Please could you recommend a good way to fix the stud wall to the Thermalite blocks? I've found
thank you!!
DEWALT AERATED CONCRETE ANCHOR NYLON 70MM
but not sure if these are the best things to use or what to put them with?thank you!!
