As per title, a screw has gone through a concealed (tiled over) 15mm plastic Speedfit pipe. The local isolation valve has been turned off, but between the valve and the hole in the pipe there is an inaccessible (again, tiled over) branch that feeds another outlet. Would like to keep using the latter branch outlet - but the one with the hole in the feed pipe isn't so important.
I can't think of any way to permanently repair the pipe without removing the original 600x300 tile (that would surely break with no replacement available).
So is there a way to seal this plastic pipe so that the other branch can still work? ie. is there some sort of chemical sealant "gunk" that can be injected into the pipe through the screw hole that would permanently block and hold in place?
Thoughts please!
From JG Speedfit website:
Thoughts please!
Chemical Effects
Only water or oil based paints should be used. Do not allow Speedfit fittings to come into contact with jointing compounds, cellulose based paints, paint thinners or strippers, solder flux or acid based descalents or aggressive cleaning products, including those below pH4, high in hypochlorite (e.g. bleach) or containing hydrogen peroxide. (SEE THE DISINFECTION OF HOT AND COLD WATER SYSTEMS section of the installation advice for specifically permitted disinfection procedures). If there is a risk of any chemical treatments coming into contact with Speedfit, please contact the Technical Advisory Service first to check compatibility.
