I am using 12mm insulated tile backer board, similar to Wedi, in our bathroom. To give space to run pipes behind the board, I am screwing 18mm by 44mm battening to the wall at 300mm spacing. The board will be glued with Mega polyurethane glue and screwed as well with washers. Will 18mm screws be long enough or do I need longer, into the wall as well?
James.
James.
