Have a brick wall that has been strapped and sheeted many years back as the houses were affected by damp. So trying to fit a kitchen wall unit and used a 8mm plug and 100x6 screw and a couple are turning in the hole. Advice please?
Fills ?A blob of filla helps settle in the plug before fixing the screw,![]()
It’s an ex council house and half of the houses were stripped and re plastered but the other half were just strapped and sheeted many years 25+Op mentioned damp which will effect anything like powdered filler. Bricks tend to crumble.
@RobTi
Look at dry rods which is something you can do to treat damp
Just hammer in a wooden plug .Think the wall is shot I must have hit mortar, pulled the no.8 plug out and tried a no.10 and it still spins, years ago I would have taken the cabinets down and used a wooden dook
Would this work if I am in the mortar rather than the brick?You can use no more nails or similar. If the wall is damp use an outdoor version. Put the nozzle deep in the hole so it fills with no air bubble. Press your plastic plug deep into the adhesive and leave it to set. You can put a long screw a couple of turns into the plug to use as a handle. Push it in below the surface and remove the excess. It has to be in the brick not the plaster as Fred says.
The adhesive prevents the plug from spinning in the hole and transmits the expansive force to the wall. Take the handles out after it has set.
It is cheaper than chemical anchors and plenty strong enough for indoor work.
As there is a delay while it hardens, do all the holes one day and all the screws the next.
This works even in difficult materials like breeze blocks or lime mortar, but remember the weakness of the material and use plenty of long screws. Cabinet hanging rail is very good for bridging weak spots and spreading the load.
