thanks. is there any special type to use. eg pozi drive or slot or phillips. any special threads, full or half. i will use a drilldriver to put them in
Use dry wall screws, 32mm will be the closest size. These have a phillips head. If you are using a power driver then its worth getting these as they will stop the screw going too deep and tearing the paper.
