Screw Sizes / Lengths
4 Jan 2006
Devon
Hi;
For fixing roofing battens to gold cladding on to the side of a timber framed workshop what size screws should I use.
The battens are 38 x 50 (D x W) and the timber that they will be screwing into is 3 x 2 (70 x 45).
According to the info I have been looking at the screw length should be no more that 2/3 the combined depth of both pieces.
So 38 + 70 = 108 / 3 = 72mm
So a 70mm screw length?
As for diameter 4 / 4.5 or 5mm?
I was taught the 'Rule of Thumb' when fixing timber the that the screw should be 2/3's in fixing, 1/3 in what is to be fixed.
However in your case 3" is an absolute minimum.
must admit i had assumed 19mm tile baton assuming 38x50 was a typo and actually 19x50mm or 19x38mm tile baton
but suppose i could have asked :D
