Screwdriver for sockets and switches
30 Mar 2015
Hi Guys,
I'm planing to replace all my sockets and switches and was wondering whether there is a recommended screw driver for this task? I have a tool station and screwfix near me.
A set like this will cover all your needs, but do yourself a favour and smash the neon driver with a hammer: they are potentially dangerous.
http://www.screwfix.com/p/1000v-insulated-vde-screwdriver-set-7-pc/18195
This set is dearer, but the handles are soft grip.
http://www.screwfix.com/p/forge-steel-vde-screwdriver-set-7-pieces/2658c
There are cheaper (but smaller) sets in Toolstation: click the catalogue page shown on this webpage.
https://www.toolstation.com/shop/p61933?table=no
There is one set here that looks well priced, but I can't find any reviews to see if it is any good.
http://www.toolstation.com/shop/Hand+Tools/d10/Screwdrivers/sd80/Soft+Grip+Screwdriver+Set/p90690
Thanks @securespark. I have a screwdriver for the faceplate and assumed that the screwdriver used internally on the sockets, switches and roses is the same size. If this is the case, what size do I need for this and can I buy that seperately? Thanks for your help.
I usually use 3 or 3.5mm blade for lighting accessories and 4mm blade for other accessories.
For consumer units I use the CK Modulo driver. Some slate them, but I found mine very good.
I want to replace them with the flush plated screwless type.
I thought the internal screws (holding in cables) are always the same size?
They are only dangerous in the hands of an idiot, and idiots should not be playing with electrics.
I have had a neon driver for over 50 years (the same one) and never come to any harm. With it I can tell the approx voltage either 220/240 or 110/120, whether it is AC or DC, and if DC the polarity. All these different scenarios I have come across.
Yes, you really have to be an idiot to be placed in danger by one of these devices.NOT.
If you can't see that, well.......
Is the OP ready to do electrical work if he needs to ask which screwdriver to use?
I think that's a bit mean - it's obviously "the straight one" or "the crossed" one, but without using the proper SIZED one, it knackers up the head of the screw. How does someone know which size to BUY if the correct sized one isn't already in the tool box? You ask some one who already has one!
Using the wrong sized flat screw driver is just as bad as sticking phillips in pozi-drive (or the other way around)
Nozzle
OK but if you're a DIY novice with no tools , do you think the first job you should do with them is to change your electrical fittings? The obvious answer to the question is to buy a set and use the ones which are the right width and thickness to fit the screws
Is there a problem with asking the experts on their recommendation for a screw driver??
I've replaced many of these in the past but not on this scale and thought it would be sensible to get a suitable driver.
So, are the internal screws the same size across the sockets and switches?
Thanks for the help.
No. And different makers have different sizes and (one of my hates) a single socket may have more than one type of screw.
Not sure what you mean by "internal screw" do you mean the ones that secure the wires?
Sorry to be vague, but it's a bit like asking what size spanner do i need to maintain my car. Fore that you'll need a socket set at the very least.
The same for electrical work, one of the sets shown in Secure's post (#2) will do for most jobs.
Some have slotted screws, some cross head, some have screws that are both cross head with a slot across do you can use either!
