I've read similar posts but seems a little different. Would appreciate thoughts.
5.5x3.5m extension. Solid floor. Subfloor and engineered wood floor covering will be continuous with existing suspended timber floor of main house
Structure (bottom to top):
150mm hardcore / sand blinding / DPM / 120mm celotex / VCL / 100mm concrete with self levelling compound. The concrete is ABOVE the insulation / VCL / DPM.
I don't like glued floating floors as they never feel quite "solid" in my experience. Not keen on adhesives if possible. Generally prefer removable fixings in case of revisions / repairs.
Id like to screw a 18mm plywood subfloor in to the concrete so I can use hidden tongue and groove screws for the engineered wood floor.
As the concrete slab is WITHIN the thermal /VCL envelope, I assume this would be fine.
Sense check?
Cheers,
Joe
Sense check?
Cheers,
Joe
